Hello, i am searching for the CCL-value that my BMS is sending to Victron:
i can see this limit in remote console device-> battery -> parameters:
in this case its 30A, because the BMS is currently sending a lower limit.
But on Modbus, i can only find the CCL that i have manually set in DVCC:
This can be found via Register 2705:
So i can only read the manual CCL-setting (register 2705) -> 100A
but not the actual CCL, victron is using as the limit -> BMS-CCL -> 30A
Are there any ideas how to read this BMS CCL??
Is there a hidden Modbus Register for that?
