mikli avatar image
mikli asked
Rpi + 5 inch touch screen - dimming issue
Hi, I bought a Waveshare 5 inch DSI touchscreen to my Raspberry Pi and it worked perfect directly out of the box. The only thing I have not managed to solve yet is to get the dimming to work to conserve energy when the screen is not in use. I have downloaded the RpiDisplaySetup but it will not install. According to the instruction I need to install from the command-line but that's where I'm stuck. How do I manage to install the package then? Any other tips to manage the dimming / standby mode of the Waveshare screen?
Raspberry Pidisplay
Kevin Windrem avatar image
Kevin Windrem answered ·
You need to run /data/RpiDisplaySetup/setup from a command line prompt either via SSH or a keyboard and mouse plugged into the Pi.
Running Venus OS on a Raspberry Pi isn't plug and play and does require some customization requiring command line (aka terminal) access along with unix knowledge.
mikli avatar image mikli commented ·
Thanks for your your reply! Unfortunately I don't have any Unix skills what so ever. Any advice on how to get back to the commandline as the Victron start screen loads automatically?
Kevin Windrem avatar image Kevin Windrem mikli commented ·
Uninstall RpiDisplaySetup from PackageManager. That should disable the local GUI.
You might consider another GX device that requires less under the hood tweaking such as Cerbo GX.
mikli avatar image mikli Kevin Windrem commented ·
Thanks again for your help! I'm learning as I go along but thanks for the advice.
Raspberry Pi running Victron’s Venus firmware - Blog Post
Venus OS Large image: Signal K and Node-RED - Install
raspberrypi install venus image
