I am considering buying the 250/70 Smart Solar..1 version is the TR--screw terminal +/- and the other has 2 x MC4 inputs
Question is do the 2 x MC4 inputs connect to 2 individual MPPT's OR just combined into one MPPT internally ?
As you suspect, the 2 pairs of mc4 connectors are combined in the mppt to a single tracker.
Pls note, each pair of mc4 are rated at 30a.
Thankyou...It will make me re think my design of having 12 panels in a row with 2 strings....especially as at the end of the panel array there is often shading which with only 1 tracker will reduce the entire array's out put significantly...
do all of Victrons MPPT 's--smart and blue configured the same--ie only one MPPT internal tracker arther than multiples ?
The SmartSolar MPPT RS solar range have multiple mppt trackers.
The 450/100 has 2 trackers, and the 450/200 has 4 trackers.
Hi @Garry414
If you have selective shading on one panel in a string then all the panels in that string get their Amps reduced. Regardless of the number of trackers. This is the issue you need to address. Multiple trackers may have little effect at all on overall output.
You may be overthinking this a little, wanting it all into one blue box. Usually in a situation like this a designer would split the panels into smaller strings (say 3x for you) and use like a 150/ mppt. More wires sure, but the mppt should be cheaper. And the shaded panels have less effect on output overall. The gains doing this would far outweigh gains from multiple trackers.
Then of course multiple trackers can be had with multiple mppts. The 150/ range goes further down in the Amp ratings than the 250/'s, so worth considering multiples.
The Victron range of mppts is massive. Many can be scratched with 48V batts, but there's plenty to work with if you can shake off those preconceived 'must-haves' that may not be as important as you think.
31 People are following this question.
