For me, the updated iPhone Ap now only shows battery temperature in celsius, used to show fahrenheit. How can I correct? Using Ap via Bluetooth with BVM-712.
Victon just updated the app so make sure you on are 5.5. Tap the three lines on the upper left, then click settings. There can you change the app wide temp unit.
Actually the problem occurred once I upgraded to v 5.5 a couple of days ago. Thank you for the tip which solved the problem. I was changing the setting between Celsius and Fahrenheit in another place in the app and it only changed the temp displayed on BVM-712 itself.
6 People are following this question.
