mercuricmind avatar image
mercuricmind asked
SmartSolar MPPTs with VE.CAN not Synchronizing
My 48v system has 2 smartsolar 250/70 MPPTs with VE.CAN daisy chained to a Cerbo GX with the color control. Each MPPT is suplplied by three 400W panels in series. I have not been able to get the mppts to synchronize and enter the same charging state. How should this be accomplished? I have not found an answer searching through the interwebs as of yet.
MPPT SmartSolar
snoobler avatar image
snoobler answered ·
Do you have a VE.Can termination plug at the beginning and end of your VE.Can string?
Have you manually configured the MPPT with identical settings?
Do you have a BMS managing the system?
mercuricmind answered ·
Thank you for commenting.
Yes I have the mppts linked with the rj45 cable and have the 120K terminators at the ends, Both mppts have the same settings. I do have a BMS and have the cerbo set with dvcc. The BMS has an internal 120k CAN terminator and I have the other terminator at the cerbo in the BMS.CAN ports. Also connected to the cerbo is a lynx shunt and distributor, and a quatro inverter charger. I have panel voltage and battery voltage at the terminals of each mppt but only one produce current.
snoobler answered ·
  1. Does the working charger show "External control" on VRM/VictronConnect?
  2. Does the non-working charger show "External control"?
  3. Are both chargers visible on VRM?
Thanks again,
To answer your questions:
1. Yes
2. Yes
3. Yes
The mppts were showing that they were in master slave mode.
I'm currently not at the installation location any more. So I will have to continue to troubleshoot when I return. I plan on physically swapping the mppts around to determine if there is either bad wiring or a bad mppt controller.
Thanks again
snoobler answered ·
I'm at a loss. Swapping seems like a good idea. I'd also try two new network cables.
