rossco85 avatar image
rossco85 asked
Multiplus 12/1600/70 chassis ground issue
Mppt 100/50 & Multiplus 12/1600/70 are both fed via the Lynx Distributor which has a 70mm2 cable to chassis ground.
Do I still need to take a cable from the chassis ground point from the Mppt & Multiplus even though the neg it’s connected to the Lynx - which is connected to the chassis ?
Thank you in advance
MPPT SmartSolar
@Rossco85
You would.need to clarify if you are in a mobile install it not here?
Grounding is application and regulation specific.
rossco85 answered ·
I’m sorry, of course I wasn’t very clear. It is in a motor home .
