gauding avatar image
gauding asked
Modbus service com.victronenergy.settings
I have a Victron Quattro 48/10k with a Cerbo GX and 2 attached BYD Premium LV batteries.
With Modbus I can read a lot of data on the 3 services that are provided automatically:
  • com.victronenergy.battery (ID 225)
  • com.victronenergy.vebus (ID 227)
  • com.victronenergy.system (ID 100)
There are a few registers (i.e. 2705 max charge current) that I would like to read and change from this service:
  • com.victronenergy.settings
How can I add this service?
Modbus TCP
wkirby avatar image
wkirby answered ·
For com.victronenergy.settings you can use ID 100
gauding answered ·
Thank you for the quick response.
This worked very well.
I can now use my Loxone server to see all data and modify some of them.
t-a-j avatar image
t-a-j answered ·
Hi @Gauding, it is possible to export your Loxone Cerbo GX Modbus Config ?
I have the same Config, but i can't read values frome Modbus.
Allways no Data.
Thanks very much.
gauding answered ·
Hi t-a-j,
I use three addresses and upload the template for each.
MB_Victron100.xml
MB_Victron225.xml
MB_Victron227.xml
I use port 502 to talk to the Cerbo GX (192.168.2.xxx:502)
Good luck!
t-a-j avatar image
t-a-j answered ·
Hi @Gauding, it work's.
Thanks very much
