Dave Rae avatar image
Dave Rae asked
Pylontech & VE_config Settings
Hello, being that Pylontech batteries are utilizing their own BMS to set charge/discharge parameters, is the step below still necessary as is stated in the official setup documentation?
5.1 General tab
  • Check the “Enable battery monitor” function
cheers.
Pylontech
Alexandra avatar image
Alexandra answered ·
@Dave Rae
Yes.
If there is a loss of comms, the system needs to know what to do as a fallback. Loss of comms can happen for quite a number of reasons.
And the internal monitor is used for ESS programming so is also needed.
Use the guidelines.
Dave Rae avatar image Dave Rae commented ·
Cheers
