jeanmarie avatar image
jeanmarie asked
scheduled charging feature
Hi everybody
I'm discovering the scheduled charging feature from ESS assistant and found out that it it mainly switch to "keep battery charged" even if the SOC isn't below setpoint : roughly useless in an ESS configuration
The only way to get what everybody would expect from this feature (keeping ESS working as it should except if SOC is below setpoint in the time span set) is to use Venus Large and node red.
Is any plan scheduled to "adjust" this feature without having to start learning node red?
thank you in advance for any advice
battery chargingESS
enodev avatar image
enodev answered ·
I am facing the similar issue I think. Scheduled charging setup from 1am to 3am to leave at 3am with 30% SOC, and when I enter at 1am with 70% SOC, the algorithm will keep powering everything from grid despite having enough battery to ignore scheduled charging completely.
magnusb avatar image
magnusb answered ·
facing the same issue - not sure what the thinking behind this is. If this is indeed intentionaly and not a bug, I would suggest to offer a switch that allows to change this behaivior and allow discharging if SOC is above the minimal level.
magnusb answered ·
ejrossouw avatar image
ejrossouw answered ·
@MagnusB The latest firmware takes care of it.
ericl avatar image ericl commented ·
This problem occurs here as well.
