What do you think about this system, any feedbacks or suggestion?
Thank you in advance from Switzerland
Alois
Alois
If you are going to use a Smart Shunt all your DC should go through it.
Battery cables for both strings need to be the same length, or you need to use bus bars.
You probably need way more solar than that, clipping when its sunny is fine but you need to think about dull short days.
You will want battery temperature monitoring too.
You should list you equipment to get better, more useful, comments
30 People are following this question.
