Melih Manisalıgil avatar image
Melih Manisalıgil asked
Temperature-CCA rates of AGM Deep Cycle Batteries
CCA rate of 165Ah AGM Deep Cycle battery is available only in 0°F / -17.8°C as 600A in datasheets. The Temperature-CCA characteristic of this model is required for my application.
The other products on the market can provide this graph.
Is there any available resource on this or any available official answer?
I just need to confirm that the CCA value between -5°C...+5°C.
Thanks in advance.
AGM Battery
Mike Dorsett avatar image
Mike Dorsett answered ·
The data shows that the CCA will be maintained down to -18C, But whilst this might be slightly higher at higher temperatures, I would use the same CCA value for your application. Exceeding the CCA figure can cause physical damage to the battery's plates.
