what are your setting for Mopeka BLE tank sensors setting for 20lbs BBQ
the % display does not match the Mopeka application
Based on my use of the device the Mopeka Pro sensor sends the % to the Venus device so it should read the same. However, mine did not at first because the Bluetooth receiver was not in a good enough position. I have a Cerbo GX and when I added a Bluetooth USB dongle on a longer USB lead closer to the LPG tank it then read the right numbers. The manual lists Bluetooth dongles that are known to work, I used the TP Link UB400.
29 People are following this question.
