gbradleyviper avatar image
gbradleyviper asked
SmartSolar MPPT VE.Can 150/100 history send CSV file button does not work
I have 2 SmartSolar MPPT 150/70 and 2 SmartSolar MPPT VE.Can 150/100 installed on a 24 volt system. The 150/70 are a year old. I installed the 2 150/100 on 08/23/2022. The 150/100 are up to date on their firmware v3.10. The bootloader is v1.06.
I can send the history csv file from both 150/70's and from one of the 150/100's. But when I press the history button on the other 150/100, the button does nothing. I have 3 Samsung PDA's and a Samsung cell phone using Bluetooth that the other 3 MPPT's send the history file just fine. The 150/100 doesn't work on any of the devices.
Any help would be appreciated,
Thank you,
Guy Bradley
MPPT SmartSolar
Hi @gbradleyviper
What is the serial number of the MPPT that does not work? Then we know the exact type so we can investigate the issue.
Regards,
Thiemo van Engelen
Hi @gbradleyviper
What would be even better is creating a service report after connecting to the failing MPPT and posting it here in a comment or answer. The procedure for creating a service report can be found here: https://ve3.nl/VictronConnect_How-to-create-a-VictronConnect-Service-Report
Kind regards,
Thiemo van Engelen
k-k avatar image
k-k answered ·
[Send csv button doesn't work]
Welcome to the club..
You might send @Thiemo van Engelen (Victron Energy staff) a message. He is working on another device with the same problem.
gbradleyviper answered ·
Hello and thank you for your response @Thiemo van Engelen (Victron Energy staff)
PN: SCC115110411. SN: HQ2140UF6PH.
I downloaded both the vcsf and the log file. I tried uploading them individually and in a zip file to this comment and I got the following error. "Something went wrong. Please try again." Please advise. My platform is Windows 7 Home Premium SP1 using Chrome Version 105.0.5195.102 (Official Build) (64-bit)
Thank you for your time and help. Guy Bradley
Hi @gbradleyviper
There seems to be a problem with the file upload function of the forum. In the mean time, can you perhaps post some screenshots of the history page? It would be nice when the values of all days are visible in a screenshot, not necessarily in the same screen shot.
Kind regards,
Thiemo van Engelen
Hello @Thiemo van Engelen (Victron Energy staff)
Thank you,
Guy Bradley
Thiemo van Engelen (Victron Energy staff) avatar image
Thiemo van Engelen (Victron Energy staff) answered ·
Hi @gbradleyviper
Thank you for the screenshots, they were helpful. We identified a problem with VictronConnect and the data export. This causes the export button to not do anything when the history contains "invalid" values. In this case, the min battery voltage of day 24 and 25 are invalid, causing the problem.
This will be solved in the next VictronConnect release, but it is not sure when this will be released. There are 2 things that you can do in the mean time:
1. Clear the history (using the clock icon on the right of the history)
or
2. Wait for 7 more days. Then all min battery voltages will be contain a valid value and the export should work again
Kind regards,
Thiemo van Engelen
Awesome. Thank you very much. That makes sense. I will wait the 7 days.
Have a nice day,
Guy Bradley
