Rune Eilertsen avatar image
Rune Eilertsen asked
Fan control Quattro 10k and 15k
Hi, we want to use Quattros in limited space, where we have thermal isolated air intake and air exit.
But it looks like fans only activate at preset loads?
( or maybe at a very high temp when no load, we need to test more)
Is the fan behavior equal for all quattroes ( 5 to 15 k )?
Anybody know the exactcriteria for fan starting on Quattro?
I was asume the internal temp alone would activate the fan, but not sure that is the case, as the top of inverter get hot, and no fan is running.
If it was possible to invert the silent assistant, to start fan instead of stop it, that would be a ok solution and use external input to regulate the machine inside temp
temperature
Kristof G. avatar image
Kristof G. answered ·
Edit:
Ok, sorry ignore my post :) didnt read all the way to the end of your post, you already know the silent assistant.
hi,
There is a silent fan assist
https://www.google.com/url?sa=t&source=web&rct=j&url=https://www.victronenergy.com/live/assistants:overview_of_available_assistants&ved=2ahUKEwjDl9DS8abiAhXQJFAKHTgBCUwQFjAAegQIAxAB&usg=AOvVaw20RCsGg9D8o0POh_PPY8VC&cshid=1558244693253
Scroll down to:
Silence fan
Disable the fans at night with a simple external switch, to ensure a quiet night. Very useful for boats and motorhomes.
