markus32 avatar image
markus32 asked
How to connect Multiplus II and Microinverters
My Setup:
12 x panels (a 400 Watt)
3 x Microinverter (Hoymiles HM-1500)
1 x DIY Lifepo4 battery (16 cells a 280ah)
I would like to buy 3 x Multiplus II 48/3000/35-32 and connect them to L1, L2 and L3. Using a current sensor I’d like to achieve zero feed in.
For the sake of simplicity lets just look a one phase:
So in my image this would be:
(A) connected to (B) : power grid and microinverter
(A) connected to (2) : power grid to ACin
(3) connected to (A) : ACout2 to power grid
So I have a direct connection between ACin and ACout2, no?
Multiplus-IIESSmicrogrid
ianjoyner avatar image
ianjoyner answered ·
ACin is bi-directional, so you don't need to connect (3) to (A).
marekp avatar image
marekp answered ·
@Markus32
Do those 3 micro-inverters work as 3 phase system?
When (A) is connected to (B) there is no way to achieve "zero feed" unless you can set (B) to "zero feed".
You cannot connect (3) to (A).
