Hi quite new to this, anybody know what settings i should use for this configuration? Thanks in advance
Pick a flooded battery preset?
It's lead calcium technology, so resistant to sulphation.
7A charge rate doesn't correspond to Victron/industry 3 stage charging. This is based on voltage, not current.
Suggest you get more info from supplier.
Your Orion will give way more than 7Amps, may damage the battery. There's no current limiting in the Orions, they charge as quickly as they can, based on voltage.
42 People are following this question.
