New ess system screen on easy solar reads low battery and also 100% charge. But victron still took 3 kw from grid why? Fault #5 is also showing how do I know if power is being taken from batteries
What is the system using as the battery monitor the Pylontec or the ve bus?
You can check under settings - system setup
In ess do you have all the dynamic cut off voltages set to 46v?
41 People are following this question.
