willem avatar image
willem asked
Pylontech charging/float
We have multiple pylontech batteries that never ridge float state and the BMS always report 99% charged. It jump between charging/discharging and never get to a state where it float.
It's in an backup system and setting have been confirmed as per Victron guide for the Pylontech.
Pylontech
dennis avatar image
dennis answered ·
mose avatar image mose commented ·
This should be an answer to geht accepted and voted.
Paul B avatar image
Paul B answered ·
Hi Willem, In Regards to your post, we would need a full list of how your site is configured and what charge voltages have been set.
a detailed list of all components and if posable a wiring diagram of the site,
its not posable to give you any answers with the information you have supplied.
willem avatar image
willem answered ·
Hi Paul. Standard configured as a backup system with 3 battery modules.
No rocket science to connect and also not my first system.
Battery type Lithium
Charge curve Fixed
Absorption voltage 53.2 V
Float voltage 53.0 V
Absorption time 1 Hr
Settings is as per Victron guide. As mentioned above
hardwic avatar image hardwic commented ·
Has anyone notices the 53.2v sent via CAN to DVCC is a static value? Once the voltage goes over 52v the BMS generates an over voltage alarm. What is the point of have DCL and CCL and CVL but populate that with a static value?
Defeats the purpose of even having CAN
Michael Timler avatar image
Michael Timler answered ·
Set 51.70V Absorption and 51.00v for Float. If you want to go for battery life expansion, set 51.60V Absorption. Last adjustment results in about 90% battery load only, just to give an idea.
This may vary a little bit due to the age and use of the battery stack.
Never charge a Pylontech US2000 on Victron defaults! Way to high default voltages.
