Herve RV Nizard avatar image
Herve RV Nizard asked
Fronius + MULTI Ii AC Coupled ESS settings
img-20220621-153017.jpgI would be happy with some help. First time installing an AC coupled system with Victron + Fronius. Have difficulties finding the good ESS Assistant settings.
Fronius PV Inv Primo 4
Multi II 48/5000
simpliPhi ion lithium batteries (client's reqrt)
NO export to grid allowed
wish to find the best setting via ESS for solar / battery priority as follows :
- Solar to supply loads via Fronius
- Excess to recharge the batteries
when no sun or not enough :
1- use from battery via MII
2. If not enough, let Grid IN but without recharging batteries.
Have set mini grid on fronius with freq shift
1 to 1 rule respected
FRONIUS on AC out (loads)
Very familiar with VS / OFF grid / DC coupled settings in VeConfig . Not too familiar with Ess.
Have read most Victron docs . looked at Fronius/Victron webinars.....
Probably missing something.
For now Grid is charging batteries and suoplyung loads ....
Thanks for any tip or link ....
ESSFronius
There are no special settings needed in the ESS assistant just say YES if it ask if there are PV inverters on AC Out.
For zero feed-in you need to change some settings in the Fronius:
https://www.victronenergy.com/live/ac_coupling:fronius
Herve RV Nizard answered ·
Thanks. will double check again. so which assistants must be loaded ? Pv inverters only ? then set the ess via gx ?
