justintherhymer avatar image
justintherhymer asked
Connectors for 2.5mm2 solar cable
I want a male & female connector to join 2.5mm twin-core solar cables (up to 5m length and 10amp). MC4s are too cumbersome with rubber-sheathed twin-core. Any suggestions please?
solar
Alexandra avatar image
Alexandra answered ·
@justintherhymer
Have you looked at MC4 to anderson connectors? I assume you panels have mC4 connections.
As an example. Then you can run with Anderson connectors after that.
justintherhymer answered ·
Thanks Alexandra. It's the right solution, but I'm struggling to find Anderson connectors with crimp ferrules as small as 14AWG
@justintherhymer
Not sure where in the world you are but amazon is a good place to start.
https://www.amazon.com/Anderson-Powerpole-Connectors-10-14-Contact/dp/B07NSKGVJY
Thanks. Managed to find a UK supplier for these SBS mini twins which are ideal: https://bae-bristol.co.uk/product/sbs-mini-connectors-gupmcss-pair-grey-guardian-automotive/. Thanks again for your advice.
