vargo avatar image
vargo asked
Battery percentage not showing on app
I have the MPPT 75/15. I downloaded the app on iOS and it gives battery voltage but not battery percentage. How can I find battery percentage on this app. Under battery it shows 0.0 amps current even though it should show a draw of current. Under state it says off and I can’t turn it on. Also, output state is off and current shows 0.0 amps when it should show some draw.
battery capacity
Murray van Graan avatar image
Murray van Graan answered ·
To see battery SOC you need to run either ESS or have a battery monitor connect, BMV700 or BMV702.
As for the charge controller we would need a diagram or picture of how your controller is connected to determine what you should be seeing on the app.
