Tommy Hartvig avatar image
Tommy Hartvig asked
Charger Disabled when no house battery is connected?
I am just wondering if I have to put my Orion-Tr Smart DC-DC 12v/12-18 in Charger Disabled mode when no house battery is connected or can i just leavening on as normal?
I could not find anything under
8.3.2. Charger Mode - Battery Settings • Charger enabled
And if I switch the Charger Enabled off is say this mode should only be used for mentainence
orion-tr smart
snoobler avatar image
snoobler answered ·
In charger mode, it's a charger. It needs battery voltage to determine what to do.
If you want to have the charger provide 12V in the absence of a battery, switch to power supply mode.
Tommy Hartvig answered ·
Thanks mate but I don't need it as a power supply when my house battery box is out of the car just want to know if I should just leave it as is or disable charging as described in 8.3.2. Charger Mode - Battery Settings • Charger enabled
Even if it say only for mentainence use?
