jonboothx avatar image
jonboothx asked
Can i chassis ground my isolated 12/12-30 DCDC
Hi All
Ive run the wrong cable from the starter battery to the house battery via the 12/12-30 and im getting voltage drop of around 1.1v when under full load
Can i chassis ground the isolated version of the 12/12-30 to allow me to double up the cabling for the ve+ running from starter battery to house battery ?
My house battery isnt currently connected to chassis ground (not sure if that makes a difference ?)
Thanks in advance
Jon
orion-tr smart
kevgermany avatar image
kevgermany answered ·
You can, it will work, but the high current may cause corrosion.
jonboothx avatar image jonboothx commented ·
Hi Kev, does the higher current cause corrosion around the chassis ground point or other places ? Does this connection need maintenance ? Any issues with the house battery not connected to ground ? Thanks
kevgermany avatar image kevgermany ♦♦ jonboothx commented ·
Not sure. Passing on a warning from an apparantly knowledgeable person on another forum.
