micha avatar image
micha asked
Pylontech Force L1 RS232 connection
Hello Community,
since August last year we run a 3 Phase Victron Multiplus II System with 3 Blocks of Pylontech Force L1 Batteries:
The System works but in the Cerbo the Battery shows wrong information:
We guess this is related to an older Firmware on the Pylontech BMSs. In addition we now (since 2 Days) get regular "Low Temperature Alarm" and "Internal failure" which went away after restarting the Battery Block. Since this morning this does not help anymore. The Failure is constant:
We would like to try a Firmware upgrade on the Batteries. We downloaded the Software Package from the Link in the Pylontech Facebook Group:
https://de-de.facebook.com/groups/300620224749566/
We Manufactured a RJ45 to Serial Cable, which works with Pylontech US2000C Batteries but we can't get a connection to the Force L1 BMS. Google shows a lot for the US2000C Series but nothing for Force L1. Regarding the RS232 connection we already wrote an E-Mail to service@pylontech.com.cn in April but never received a response.
Has anybody experience with Firmware upgrade or RS232 connection on Pylontech Force L1 Batteries and can provide a short guide?
Pylontech
Delta Victor avatar image Delta Victor commented ·
I was looking at your pictures and noticed there is no can Terminator on de CerboGX. Any reason for this?
bm97ppc avatar image
bm97ppc answered ·
I had quite a bit of pain with the Force L2. It turned out to be the link cable between the stacks. Try a short (1 Metre) Sheilded patch cable between the stacks.
As for the Diagnostic cable whcih I was try to use to diagnose the issue I had the same problem. The cable I made up as per document Pylontech sent me it would only work with US200C not the L2. I have not confirmed this as I have not retried my original cable (as I got sent a genuine cable) but it seems the seriel/usb converter is very fussy on the Force L2's. I got sent the USB and the cable and it worked straight away.
Gerardo avatar image
Gerardo answered ·
Hi Micha,
It seems like a communication interference issue due to the RJ45 cable. Are you using the type-A cable to communicate the Force-L to the GX?
The difference between type-A and type-B is the grounding, and when the cable is long or it is being used in a RF environment, a wrong grounding could cause communication error.
Regards,
