andy-n avatar image
andy-n asked
Smart phoenix Inverter 12/2000 230v frequency issues
Above inverter is installed in a vehicle, all professionally installed, I have an LG 1000W inverter Microwave installed.
Question: The time (clock) on microwave has increased 45 minutes in about 2 weeks.
Inverter is on factory defaults ie 50Hz as per Australian standard.
Help would be appreciated. More a nuisance issue than operational issue.
cascading inverters
klim8skeptic avatar image
klim8skeptic answered ·
Apparently odd harmonics from inverters will cause accuracy drift in clocks that derive their timekeeping via mains frequency.
southsideph avatar image
southsideph answered ·
All clocks that use the alternating frequency reference can drift. On grid the generating company adjust the frequency during the day to compensate/correct any drift. Unfortunately using an inverter you do not get this compensation/correction so you will always get some drift
andy-n avatar image andy-n commented ·
But 45 minutes in 2 weeks, that's a very big time advance. Thanks for yours and other answer.
klim8skeptic avatar image klim8skeptic ♦ andy-n commented ·
Maybe run the ac through a power filter board.?
Might work, might not.
southsideph avatar image southsideph andy-n commented ·
Unfortunately phase frequency can be affected by many different factors, including load, capacitance, inductance, resistance, cables, tolerance of the components used etc.
Although the stated frequency is 50Hz could be +- 0.1% for example. It is still only the centre point between the two tolerances, which could be 49.5Hz and 50.5Hz, which would either cause a clock (50Hz Referenced) to either loose time or gain time.
