markaos avatar image
markaos asked
100/20 mppt power a 12/250 inverter (max 100 watts) and a 12v DC diaphragm water pump?
Hello.
I need to stabilize water level in a lake as well as provide aeration.
System components so far.
330w Ja panel
100/20 mppt
12/250 phoenix inverter
Ac 39w diaphragm air pump
Dc water pump control
12v Dc diaphragm water pump 72w 3.9amp
Can the load output on mppt be split between the inverter and water pump or have water pump Control direct from the battery. If the later will this mess with MPPT reading battery voltage?
Thanks in advance
Marcus
mppt state
