Can I use 2x of these panels in series on a Victron Smartsolar 100/30?
Polycrystalline STC rated at 260w
Peak Efficiency 15.76%
Number of Cells 60
Imp 8.5A
Vmp 30.7V
Isc 9.01A
Voc 37.8V
NOCT 45.7°C
Number of Cells 60
Imp 8.5A
Vmp 30.7V
Isc 9.01A
Voc 37.8V
NOCT 45.7°C
It will work but the MPPT will restrict max output of the panels if you're running a 12V battery bank.
You also need to check the temperature compensation for low temperature voltage increases
Sug gest you Google the Victron online solar calculator and run the calcs through there, it will recommend a larger unit.
I know under ideal circumstances I'd be loosing some output but I'm fine with that provided the SCC can deal with it.
24 People are following this question.
