knownot avatar image
knownot asked
using swollen lipo batteries
I know the surgeon general recommends against it but I got a deal on some us2000 that had been allowed to sit discharged for some time. Cell voltage had dropped to about 1.2. I gently recharged them (c/20) to about 3.2 then hooked them up to the easysolar to finish them off. Early indications look good - no crazy self discharge, some capacity even though only half charged. Anyone else here used swollen lipo's? One pack I may no be able to put the cover back on due to the swelling - although it behaved similar to the other less swollen ones.
Pylontech
wkirby avatar image
wkirby answered ·
Once the cells have been deeply discharged they will be permanently damaged. The swelling indicates severe damage and they will be almost useless because the separator is damaged.
A better option is to remove the cells and have them re-cycled and then strip the rest of the unit down for spare parts and scrap metal.
Using damaged components is kind of like driving around in a car with partially inflated tyres with no treads remaining. It will drive, but it will be dangerous and unpredictable.
10 comments
marekp avatar image marekp commented ·
@WKirby
Why scrap the boxes when you can use them after replacing just the cells. Case and internal BMS has value.
wkirby avatar image wkirby ♦♦ marekp commented ·
Even better idea assuming you can find some replacement cells for reasonable cost. If the cost for replacement cells + effort is more than a new module then maybe not.
knownot avatar image knownot commented ·
@WKirby @MarekP So I have 3 us2000 that were connected to the same failed inverter (I think fully discharged) then left for a year. In each module the 3 cell packs are very similar. One all look normal, one all slightly swelled, one all very swelled. All 9 cell packs behaved similarly electrically. For my own interest I'll bring these packs back to working voltage (supervised) and test their capacity. I know the usual outcome should be that all these batteries have very low capacity(ie. useless), but I doubt it is the case here. I'll post my findings.
snoobler avatar image snoobler knownot commented ·
Lithium, including LFP, suffers substantially when deeply discharged, especially if they remain their for an extended period. I have 80+ 40Ah CALB cells. All but 5 of them were deeply discharged to 0.6V and held there for a very long time. The battery monitoring boards attached to each cell drained them @ microA currents even after they were supposed to shut off.
All recovered to 60-80% of their rated capacity with ONE big difference. All those that discharged to 0.6V had much higher internal resistance, 3-4mΩ, where those that held at about 3.30V over the same period are in the 0.8-1.0mΩ.
Higher IR means more heat, less efficiency and shorter life.
Do yourself a favor and buy a YR-1035 IR tester and test 100% of the cells individually. Don't use any outlier cells.
marekp avatar image marekp knownot commented ·
@knownot
I am with @snoobler on this.
I also have a bunch of calls that were deeeeeply discharged and they came back with a proper voltage and even capacity is close to 90%. Problem is that this capacity can only be achieved by veeery low charge and discharge rate (0.01C).
If I start charging and discharging them with even 0.1C, their capacity drop quick because energy is converted to heat.
The only application I found for them is in flashlight and emergency lighting. :)
knownot avatar image knownot marekp commented ·
@MarekP @snoobler all of what you are saying agrees with conventional experience - although some have shared my experience. At BMS controlled charge rate and approx 1000w discharge I appear to have 2.3 kwhrs on the intermediately swollen pack. I will take the advice about monitoring cell temp more accurately (I'll be doing a few cycles to test and monitor) although a regular feel detects no warmth whatsoever. The most swollen pack looks too scary so won't be returned to unattended use.
@knownot
Be extra caution.
If you want to be even more "hard-core", you can use a needle to puncture the outer shell of the pouch and let the gas out. Than cover the hole with the tape.
That comment sent me down an rc battery rabbit hole. It seems there's at least 2 types of swelling - one that is just gas lifting the outer enclosure and the other that involves the cell layers. In the first piercing can have a benefit (to fit the cell back in the case) in the second it ruins the cell. I suspect I have the second situation so I'll be just playing with the module as is - I'm thinking an overvolted electric scooter (donuts, wheelies etc)...
Buy a YR-1035. check internal resistance.
knownot avatar image knownot snoobler commented ·
Ordered, thanks
kevgermany avatar image
kevgermany answered ·
Hope your insurance will cover the fire this is likely to cause.
