ben avatar image
Feature Request: Reset generator start/stop logic
From time to time, the auto genstart/stop feature on my Venus device gets out of sync with the state of the generator. This happens primarily for two reasons:
1) Despite my system meeting one or more of the Conditions for auto-start, I decide after the generator is running that I do not want to auto-start this time.
Or,
2) While the generator is running, for some external reason unrelated to the Venus logic, I need to stop the generator. Then, Venus thinks the generator is running, while it is not. (And vice versa, in my particular setup.)
In both of these cases, we need a way to tell Venus to "reset what you know and start over" in terms of the logic. Short of rebooting the whole unit, I don't see a way to do this today.
feature request
6 comments
Is there a way to programmatically reset those flags, manually, behind the scenes?
Unfortunately, I don't think so.
Bummer... and surprising, considering all the stuff you can do with it :)
As far as I (thought) knew, it's just a simple little script to demo some sample automation.
Well, I'm sure the driver could be modified. I guess I should clarify that the values it posts to dbus don't offer an obvious way to reset it.
I think all we need is a button to either restart the script (which I think will cause it drop all its state) or a reset feature within the driver.
Ahh, I understand.
Alas, I don't know how much priority V will give to it, but I agree it'd be useful.
I can certainly see situations where I'd want to stop my genny outside the script (like using those handy little switches on it).
What happens if you just run the script again, anyway, essentially doubling the stop/start functions? On my genset stopping or starting "twice" does nothing.
I suspect they'll collide if there are two trying to register themselves, at least without a little tweaking.
That said, our generator start and stop pulse is the same, so a double pulse wouldn't work in our case. Boo.
Paul B avatar image
No there is no way to reset it
if the G/A/S starts from a condition thats set then it has to be stopped by that conditions Stop Value.
best way to do it is to adjust the stop value at that time so that it stops.
or even use the Quite Hours function to have diferant setting during the day to whats required at night etc etc.
I try to get the system to be a close to auto as possible.
even use the periodic run time as a reset feature if you like, say start gen at 7pm daily and charge until full
1 comment Share
Yes, I know that it can't be done. That's why I made it a feature request. :)
