ips-ad avatar image
ips-ad asked
Kostal plugin leads to incorrect VRM dashboard (rounds to full kWh)
We're using a Kostal Piko 7.5 with the plugin (https://github.com/schenlap/venus_kostal_pico), which works great locally. I set the interval to 5 seconds for polling the Piko.
But, in the VRM portal, it looks like only rounded kWh values arrive from the Piko, which leads to wrong production and wrong consumption values.
1649422460477.pngThis is the setup (single phase ESS with EM24 as grid meter, 3 phase Piko and grid, MultiPlus II connected to L1 of AC input).
1649422659372.pngI'm not sure if I missed something in the config of the plugin?
Thanks for any ideas and hints!
ESSdashboard display
gnagflow avatar image
gnagflow answered ·
Hi, just a question. Do you receive values for L1, L2 and L3 for your Kostal plugin?
I only receive L1 and also i have the same problem as you with rounded values to full kwh.
thank you.
ankaoha avatar image ankaoha commented ·
My Plugin works fine. All three L shows
ankaoha answered ·
I have the same problem. Is there already a solution?
What is ESS training video
ESS Quick Installation Guide
ESS design and installation manual
