tpwchr avatar image
tpwchr asked
Finally got this amazing set-up! Question about limiting charge
Hi everyone! Finally I have been able to get all the components for my off-grid installation:
- 12x 450Wp panles
- 3x US3000B Pylons
- MPII 5000
- Cerbo GX
- MPPT 250V100
I am reading through the compatibility document: https://www.victronenergy.com/live/battery_compatibility:pylontech_phantom and I am wondering if I should limit the charge current to a % less than 100% to preserver the battery. ATM it's going until 100% because I haven't really configured it yet, I couldnt connect the MP with the MK3 to the laptop.
Thanks a lot!
Pylontech
shaneyake avatar image
shaneyake answered ·
Nope, it is fine to go to 100%. It is an LFP battery. You can lower the max voltage tho, as the BMS likes to push the cells. On the GX -> Settings -> DVCC -> Limit Voltage. I like to set it at 52V or about but after a few days it will go back to saying 100% SOC but I think this has been set by default in latest firmware. You can see the "My system only charges the battery to 52.4V" in that doc.
tpwchr avatar image
tpwchr answered ·
Thank you!! I will try to connect it with my MK3. Should I use VE Configure or victronconnect?
shaneyake avatar image shaneyake commented ·
VE Configure to configure the Inverter and Victronconnect to configure the MPPTs.
You don't need to use a MK3 if your Cerbo has internet. You can just use it to download and upload the VE Configure files. Remote VEConfigure under device list on VRM.
tpwchr avatar image tpwchr shaneyake commented ·
So I could set up everything remotely? MPII and MPPT?
