on your remote portal (app) it shows approximate hrs left, is this to % SOC or is it to the minimum SOC you setup ? (ESS system)
I'm guessing you're reading a BMV or BMS connected to the system?
Than it's the settings in the BMV / BMS that make the target.
5 People are following this question.
