racerke600 avatar image
racerke600 asked
VARTA AGM VW California
Recently installed a 75/15 with two 120 watt panels, all connected to 2 Varta AGM's in my vw california.
The standard battery setting suggests option 2, but that uses only 14,4V voor absorption?
When I look up the data from varta, they suggest charging with 14,8 V.
I also tested when I had the car in the garage on the mains (230v) what the internal charger would give, after a certain amount of time the voltage was already +14,5V.
Another test with the engine running showed the voltage exceeding >14,8V(14,9V)
So my questions is, is it okay for me to make a custom battery profile with 14,8V to charge and 13,8V for float? All the other variables don't seem to change much between the different pre configured settings. The only things that matter seem to be those two voltages?
Thanks in advance.
AGM Battery
Hi @Racerke600,
it absolutely necessary and ok to adapt the charge profile to the battery manufactures suggestion.
About the voltage increase: that's most probably due to temperature compensation. See also the manual for your MPPT.
tattersp avatar image
tattersp answered ·
Did you find this worked for your Varta battery?
