Have recently installed the Orion non isolated charger. Have wired it in as per instructions but lights not turning on. Device not showing on Bluetooth app either. Power to the unit working.
Any help appreciated.
Guessing you measured input power at the charger. Do you also have voltage on the output side?
What did you do with the L and H connections? Is the bridge still there? Or did you do something different?
Make sure the remote jumper wire/plug is in place if using engine run detection feature or make sure to install a switch to the remote plug and that the switch is on.
Yes power at output side. Fitted bridge after connecting starter battery to unit. Have yet to connect to leisure batteries as it wouldn't turn on and couldn't setup via the app.
32 People are following this question.
