garyw avatar image
garyw asked
Orion DC DC fluctuating input voltage
Just installed a new Orion 30 amp and set it up for auto detect engine running. Doesn’t work, in the app the input voltage is fluctuating massively between 2 and 14 volts all the time. Multimeter shows it’s at 13.8 with engine running and should be charging. Any thoughts ? It fitted an Orion before but I have a lot of Victron in a few vans..
orion-tr smart
wkirby avatar image wkirby ♦♦ commented ·
Where about are you probing with the Multimeter when you get the 13.8V reading?
garyw avatar image garyw commented ·
On the vehicle battery connection on the Orion and to chassis ground.
kevgermany avatar image
kevgermany answered ·
If the input side of the Orion fluctuates so much, there's probably a wiring fault.
