patryk avatar image
patryk asked
Pylontech US2000 C - BatteryProtect
Good morning,
I am building a yacht on which I want to use Pylontech US2000 C and MultiPlus II GX and MPPT.
Please advise if I need to use Battery Protect to protect the battery when I connect other 48V DC devices ? Does the battery have ATC and ATD signal?
Does the battery have an internal contactor to cut off current consumption?
Pylontech
wkirby avatar image
wkirby answered ·
Czesc
Przepraszam, nie mowie po Polsku.
You should not use a contact or Battery Protect with Pylontech. They have their own disconnect devices inside. All protection is inside each Pylontech battery.
patryk avatar image patryk commented ·
Thanks for the reply, I couldn't find anywhere that it has an internal load cut off on charge and discharge. (I already corrected the text to English, sorry)
wkirby avatar image wkirby ♦♦ patryk commented ·
In the Pylontech manual is says:
patryk avatar image patryk wkirby ♦♦ commented ·
In the manual I found :1644234631336.png
That's why I thought I had to use Battery Protect
markus avatar image
markus answered ·
this is an English community. Please use a translator, so more people are able to help.
See this info about Pylontech batteries in a Victron system.
There you will find the proper settings, minimum module configuration and even a schematic how to wire the modules:
Victron & Pylontech UP2500, US2000, US3000, US2000C, US3000C, UP5000, Phantom-S, Force-L1 & L2 [Victron Energy]
BR
Sorry for the text not in English, already corrected.
I've read the information on the Victron website, however I didn't get an answer how to protect the battery from discharging when I connect other 48V DC loads (except MultiPlus)
