nick-b1983 avatar image
nick-b1983 asked
3 Phase Quattro System with 2 x Inverters per Phase
Good Morning
I have an installation with 6 x Quattro 8000 Inverters in 3 Phase connection.
I have set it up using the VE Bus System Configurator and sent all settings. I have 0 errors and all seem to be working fine, however, I have blinking lights on the slave units. It jumps between the inverter on and Mains on green LED's.
Further, I have installed the ESS assistant on all units, however my Venus GX does not seem to see or recognize the assistants. I need to set up the ESS on the VENUS.
What could be the reason for this?
Is there another step to set up Master and Slave configurations for the 3 Phases?
Or am I missing something?
Nick
system design
The blinking on the slaves is normal.
Check again if the assistant is correctly added to the Quattros.
marekp avatar image
marekp answered ·
@Nick B1983
Blinking LED-s on slave unit is normal. It just tells you which one is a slave.
After answering all the questions during a assistant setup ("start assistant" button), you have to press "send settings" button in order to load assistant to your Quattro.
