I am adding 2 x UP2500 Pylontechs to my Victron Multiplus system. I am struggling to find the charge settings (Bulk and float)
Can anyone help?
Can anyone help?
Should be in the datasheet/manual of the batteries.
The UP2500 should be a normal 8S setup with nominal 25,6V.
So I guess you can use the normal lithium settings.
(The 48V US2000/US3000 is a 15S setup instead of the normal 16S)
Likewise, the letter "P" is used for parallel connected cells or modules or strings.
37 People are following this question.
