andre12 avatar image
andre12 asked
MPPT search with Multiplus 2 48/5000 and Trina moduls
Hello !
I want to install one Multiplus 2 48/5000
with Trina TSM-400 DE09.08 Panels 400WP
should i use 12 panels 4800wp or 15 panels 6000wp
the direction is south west without any shade
with the 15 panels i could run 2 option's
3S5P 123V 46,9A with a 150/70 MPPT
15 Panels in 5S3P 206 V 28A with 250/60 MPPT
or is that better to install only 12 Panels !?
what should i add in the mppt caculator on this 2 points V Temp.-Koeff. [%/°C]
I Temp.-Koeff. [%/°C
the whole system is running later with 2 Pylontech, EM24 as a grid parallel island
thanks for your Help i'm doing that the first time :)
Bye Andre
Venus OS
Mike Dorsett avatar image
Mike Dorsett answered ·
The number of PV modules you install is determined by how much energy you are using on a daily basis. Depending where you are, a 400W module will produce between 1 to 2 kWh per day. The temperature coefficients are on the module data sheet which you can get on line.
andre12 answered ·
I know that,
i'm searching the best way should i do 12 or 15 panels
andre12 answered ·
should i use the STC Data or the NOCT Data
i calculated for now with the STC Data https://mppt.victronenergy.com#djE7Y3VzdG9tLDMsNSw1NCwtMzAsNzAsNDgsMTEuNywwLjA0LDEyLjI4LDQwMCwzNC4yLC0wLjI1LDQxLjIsMTAsNg==
why is in the calcalation V at max Temp red ??
