We have two Lifeline 6v 400 Ah AGM batteries connected in series with a 210 Watt solar panel and a MPPT 75/15 controller. While setting up the controller what presets should I use? There is one for spiral AGM, is there much difference?
There is a difference. You need to check what internal construction the batteries have
25 People are following this question.
