Setup went well but the 'Local Time' is actually GMT. Have looked through manuals but can't find where to change to Australian EST. Thoughts?
I have found that my location setting doesn't stick on the first try. Once I'm in "set location", I often need to click "reset", and then reenter the location and click "save". Then I go back and check the local time on the dashboard, and if it hasn't updated then I go through those steps again. Sometimes it works on the first try, but others require multiple resets. I haven't had to do more than 5 resets, but it frequently takes more than 2 before it sticks.
27 People are following this question.
