bpierce815 avatar image
bpierce815 asked
Victron solar charger stops working
I have seen a similar question posted here, but no response. My smart solar controller stops working (no charge or Bluetooth). A reset using the breaker after the sun goes down works, but it has happened 3 times now.
MPPT ControllersBluetooth
Jean-Luc avatar image
Jean-Luc answered ·
I allredy have this pb or idea... Be sure that your battery tension < Bulk tension pre-configured. If you Bluetooth (on smartsolar), you can find the two elements. On smart BT, or VE.bus, you can set ON or OFF your device. Be sure it is set ON.
