mvader (Victron Energy) asked
GuiMods on v2.80~24 issue
As reported by @dsfas9 , there seems to be an issue with the gui mods.
the complaint was: "Getting blank page running ~24 with Gui Mods. Reverted to ~17 to fix the issue."
I've made a separate question here; to keep it out of the main ~24 thread .
@Kevin Windrem
here the screenshot:
Venus OS
Kevin Windrem avatar image
Kevin Windrem answered ·
This should be fixed now with v3.16.
dsfas9 avatar image
dsfas9 answered ·
@Kevin Windrem did something change to auto update? I am stuck on v3.15 and setup helper 2.10
Oops. The current tag didn't get created for GuiMods v3.16. Should be OK now.
5 comments
Still blank on v3.16, but auto-update worked.
Did you ever get this resolved? The line in the log about OverviewHubEnhanced on line 300 doesn't make sense since the line doesn't contain the missing property "active". I'm pretty sure that is what I changed from v3.14 to v3.15 to fix the white screen.
@Kevin Windrem still blank even with v3.16
Are you sure v3.16 is actually installed? Check the versions on the GuiMods Packages page.
If that page shows v3.16, then I would try uninstalling GuiMods then reinstalling it.
As I explained, the line in the log refers to a line in OverviewHubEnhanced that was changed, so what's actually bring used is not the current version.
