Javier Pardo avatar image
Javier Pardo asked
Recommendation of DC distribution system (Busbar) and connecting cable
Hello, I would like you to recommend a DC distribution system capable of supporting the amount of batteries I have installed.
My installation consists of:
- 16 Pylontech US200C batteries
- Victron Quattro 15000VA
- 3 MPPT Victron Smart Solar
The batteries are in groups of 4 units so in this case I need a DC distribution system for 7 positive cables + 7 negative cables (In both cases, negative and positive, 4 for the batteries and 3 for the MPPT)
On the other hand I would like to know what type of connection cable should I use to connect the DC distributor with the inverter. I understand that the maximum power that the cable must withstand is 300A. The distance between the DC distributor and the inverter will be approximately 1 meter.
Could you tell me what type of DC distributor and what type of cable would be suitable for my installation?
Thanks.
Pylontech
bunookana avatar image
bunookana answered ·
Victron makes some very nice bus bars to handle exactly what your asking for. Totally worth the money in my opinion
https://www.victronenergy.com/dc-distribution-systems
For your fused loads: https://www.victronenergy.com/dc-distribution-systems/lynx-distributor
for you battery banks: https://www.victronenergy.com/dc-distribution-systems/lynx-power-in
shaneyake avatar image shaneyake commented ·
I use the Victron Lynx Busbar system on all our installs. Works really well.
You can install Fuses in the Power-In but you will need to add your own Stainless M8 bolts, washers and nuts to the middle. Distributor already has them installed.
