pau1phi11ips avatar image
pau1phi11ips asked
Setting negative grid setpoint limited to 80W feed in
Hi, I have a Multiplus II 3000 24V with a 7kWh LiFePO4 battery in a campervan that's connected to my houses mains supply.
I have ESS installed and using the scheduled charging setting on the Cerbo as I have a very low electricity rate in the night. This works great!
I've tried setting the Grid Setpoint to -250W to offset the base load of the house during the day when electricity costs are high but it seems the most I can feed back in is around 80W. It doesn't matter how low the Grid Setpoint value is set, it never feeds in more power.
Am I missing something here?
  • Multi Firmware version: 481
  • Venus OS version: 273.1
ESSess grid setpoint not reached
pau1phi11ips answered ·
Hmm, just updated Venus to 280.16 and it worked. I could set 300W and it put 300W back, 400W and it put 400W.
Then it switched to Passthru and it was at 0W and I couldn't change it at all.
Going into the Settings > Multiplus-II > Advanced > System Reset fixed it.
netrange avatar image
netrange answered ·
Some Infos about your Multi !!! 12,24 or 48 Volt ...
pau1phi11ips avatar image pau1phi11ips commented ·
Added to OP, it's 24V
netrange avatar image netrange pau1phi11ips commented ·
Settings in Ess ... maybe an activated Feed back to Grid Limit ...
pau1phi11ips avatar image pau1phi11ips netrange commented ·
No feed in limit set. It's purely coming from battery power at the moment that's been charged on the cheap rate.
There is a MPPT connected to the Cerbo but I shall be installing solar later and, hopefully feeding that back in too.
PS. Why would the voltage of the Multi change anything?
What is ESS training video
ESS Quick Installation Guide
ESS design and installation manual
