Tomas Hansson avatar image
Tomas Hansson asked
BYD LVS in cold weather
I have a project where the customer is very interested in using a BYD LVS battery. The project is for a summer cottage and will only be used in the summer so there is no need for high performance during cold weather.
But, as I understood the BYD battiers shuts down below -10deg
This is no problem, but my question is, does the shut down generate any error that needs to be reset manually or does it function normally when the temperature is within limits again ?
The system will be made of Multiplus and a Color control GX (or a Cerbo GX)
BYD
