Zapped Victron smartsolar 100/20 mppt
6 weeks ago I installed a victron multiplus-ii 48v/3000va 35-32
With 2 x 25.6v lifepo4 batteries in series giving me my 48v
Also Victron smart battery shunt
All of which have been working fautlessly
Last week I installed a Victron smartsolar 100/20 Mppt
With 2 x 290w solar panels in series
Voc 39.9
Vmpp 31.4v
Isc 9.97A
Impp 9.33A
All solar cabling 6mm2
They are laid flat on my hobby shed roof so will never Max out
The mppt was charging my battery setup for 3 days no problem at all
However on the 4th day while the solar was charging my battery I decided to switch on the multiplus-ii in passthrough mode
Ie: inverter on
That’s was when the mppt immediatelyblew its 25amp fuse
I replaced the fuse but all I got was smoke emitting from the mppt, now completely zapped
Can anyone please throw some light on this problem before I contact my mppt supplier
Thanks in anticipation
Your battery decided? So i guess youve setup some minimal SOC that then turns on the MP? If it can switch to passthrough, then some mains voltage needs to be present
Do you have a schematic of the system? This sounds to me like you have some grounding issue. The smaller MPPTs are not isolated, both battery and PV negative are common. Battery negative is usually also grounded, same for the incoming neutral of the mains voltage and the MP housing. There could some rouge current flowing trough the DC systems negative if things are not done properly, but thats very dependent on the situation
Please excuse this question; I’m not trying to talk down to you. Did you connect the MultiPlus to the load output of the MPPT? I hope not. As @chigru suggested, send us your wiring diagram and we’ll be able to help further. If you don’t have a schematic, then you should make one. That’s a great way to find errors before making any connections.
The other thing is are the solar panels in series or parallel, the 100/20 has a 20A input limit per the datasheet and if your panels are in parallel then you are very close to that limit You can also check it in the Victron MPPT Calculator. I do not know how that could have caused the failure, but you need to make sure your install is designed right.
Hello
They are in series
Hello chrigu
Thanks for reply
I have created a schematic image of the setup
but it appears there is no way to upload it
Please advise if you know how
Also the grounding point you made crossed my mind, but AC side is grounded
Thanks
When you are in the reply box there should be an icon with a bar at the bottom and an up arrow, this is for uploading files. On different devices it appears slightly different.
I think thats not possible if your account on here is too fresh
Hope this helps
Someone sent me the know how to upload
Thanks for that info
I was looking for the typical image icon
Managed to do the upload
Hello
No nothing connected to mppt load
Have uploaded image to chrigu
