Hi everyone,
I’m currently rebuilding an old RV and recently installed a Victron Energy system, but I’m running into some issues I hope you can help with.
Here’s my setup:
- Victron SmartSolar MPPT 100/30
- 2x 200W solar panels in parallel
- 2x 140Ah AGM batteries in series (so 12v
- Victron battery monitor bmv-700
The batteries are brand new and the system is only a couple of weeks old. However, I’m seeing strange behavior:
- The bmv-700 shows the battery is charging very slowly — about 1–1.5% per day, currently at 74%.
- In the VictronConnect app, the MPPT often shows 0W input, even on sunny days.
- Occasionally it charges between 40–160W, but this is inconsistent. 1 every 15 days or so
- The Total Yield (Wh) in the MPPT app still shows 0, even though I’ve seen some watts going through before.
I’ve checked:
- Fuses — no blown fuses between the MPPT and batteries as far as I can see
- MPPT fuse — appears fine (I assume I’d see an error otherwise?).
- Connections — all look tight and secure.
- Settings — using preset 2 in the MPPT.
I went back to the store I bought it from, but they don’t offer support. Victron said they don’t support end users directly. And the local RV shop wants to take the whole system out and redo it for ~€3k, which I’d really like to avoid — everything is brand new and I feel like it might just be a configuration or wiring issue.
I’d really appreciate any help or ideas on what to check. Would uploading some screenshots of my MPPT and battery monitor settings help? I’m fairly new to Victron, so any guidance would be great.
Thanks so much in advance ![]()
p.s. attached screenshot of the app and a photo of the battery monitor
