Who has a 3-phase RS Multi system?
Who has a 3-phase RS Multi system and can report on it or has problems with it?
Especially the connection to the CerboGX would be interesting.
Many thanks and best regards,
Kai
Hallo,
I would also be interested in the experiences
I have it
@evgeniy.labunskiy
Hello Yevhenii,
thanks for the answer.
Is your RS system displayed in the device list in the GX device?
Kai
Sure it is
Not the same as your spec, but a 3 phase Multi RS with an Ekrano and BYD batteries was installed as soon as three phase with the RS became an option.
Zero issues to date.
Have moved the system through all the updates.
@evgeniy.labunskiy
What are your CAN settings?
Do you have ESS active in the RS Multi settings in the respective device?
Problem solved.
After the updates of the RS Multis, where the ESS function was introduced, I had never set anything there.
The settings under ESS therefore remained empty.
After I selected a value there, the RS system appeared on the device list.
