W-111 : Display firmware update error - updating EVCS from 1.23 to 2.05
I have a freshly installed EVCS at a customer. I installed the little power enhancer circuit that was in the packaging and at 1.23 the station was behaving normally.
After i updated to firmware version 2.05 the base system is trying to do the update for the display firmware, but that fails.
Behavior is that its a round trip game:
  1. Display firmware update starts … writes data till exactly 98304 bytes fast … then stopps
  2. Then it waits for roughly 30seconds (didn’t stop that)
  3. Seems to reset and writes a message “System Data ERROR!”
  4. after a couple seconds the game starts again
Interresting is thats always the exact same place where it gets stuck updating. For testing i tried to go back to V1.30 and then to V2.02 …. but that changed nothing.
So now im stuck a bit :face_with_spiral_eyes: Any advice what i could do?
Hello @W4Steli. It might be some problems with display communication. I can check that EVCS if you add me to VRM installation. Will send you PM.
i have updated my charging station also.
Version 1.23 to EVCS_Main_FW_OTA_V02.05_C025.evcsup
After that the display shows only : System Data ERROR!
Now my question.
Should i update again or was it the wrong Update?
There are 3 Versions of 2.05 and i have updated V02.05_C025.
EVCS_Main_FW_OTA_V02.05_C024.evcsup
EVCS_Main_FW_OTA_V02.05_C026.evcsup
Because it was V 1.23 at least installed.
Can me help someone with that problem?
Thanks…
This is an old bug, sometimes you have to try to install the update multiple times.
Ok, thank you very much.
I try again, may be it works…
I will give you feedback.
Thank you
